メインコンテンツにスキップ
Is the camera fixable if it fails to work?
The camera stopped working after a fall. The machine was off and closed at the time. There is a shallow dent about two inches to the left of the camera along the front edge.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
Thanks guys. Now i have an idea of what to look for. Much obliged!
さんによる
コメントを追加
2件の回答
最も参考になった回答
From your decription it's pretty likely that your iSight cam / board is gone. You will have to dismantel the display panel to get access but it's fairly easy.
You'll find the board here.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Just about anything can be fixed. It is difficult to determine the issue without proper hardware experience. You can try to replace pieces and hope that they are the affected parts. Or you can take your MacBook Pro in for service. Use this Service Locator from Apple to find the nearest service center.
Assuming that it is just the camera it may be possible that this individual part can be replaced. If not, or if other parts are effected, prepare for a greater service cost.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
lettisam さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 621
