メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
7.9 inch display / Model A1454 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
31の回答 すべてを表示
missing 2 elements on motherboard LCD is black, backlight is ok
A1455
after replace digitizer i have no backlight. after make jumper baclight back on place but LCD dont show anything. after i open case of motherboard i will see that 2 elements missing. can anyone help me in check which elements missing capacitor or resistor and what is value of this elements. thx for help
http://nextserv.pl/images/missing_elemen...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Hello, I had almost the same problem: Problem with the LCD after replacement
przemohebel did you solve this?
さんによる
コメントを追加
2件の回答
最も参考になった回答
what happened to this one? Those components can totally be replaced and this iPad mini will live.
It is odd that in your inset the two big caps are obviously missing (and yes, the one on the left is required for the image production voltage---don't have schematic on this laptop or i'd post the details of it)--but the component, as well as the backlight fuse, is present in the other image.
この回答は役に立ちましたか?
スコア 1
コメントを追加
Is this your phone or a job for someone else? I dont understand how parts from the motherboard could just be missing try looking up images of that motherboard and comparing if it worked before you repaired it then it stopped working suspect yourself if it was already broken and you dont know why and its not your phone then look for another to compare it against somehow. Ive seen tons of boards that look like they have components missing but thats just what it looks like.
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
przemohebel さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 867
