First heres the best guide on decoding AHT error codes: CNET - How to invoke and interpret the Apple hardware tests. So lets decipher yours here:
4SNS/1/C0000008: T POP--124
The next one looks like a multiple
- P - Power Bus
- OP - Optical Drive
So what does this all mean? Sorry to say not much ;-{
The problem is you can't depend on AHT alone here. You need to so a little more diagnoses to figure out whats up. Some of your actions also help here in removing possibilities, but only to a point. Water damaged systems can still have issues that one would not think of like wiring harnesses or sensors that didn't get swapped. I think your on the right track looking at the sensors but before you start taking the system a part again lets do a little more testing.
OK what is the next steps here:
I would get a temperature monitoring app installed to see what it tells you. I like Temperature Gauge which you can download from the App Store (others will also work).
The other thing here is running Activity Monitor and look at what process is running. Often this can offer a clue or it could lead to a bad app or malware app that is causing your system to overheat.
Tell us what you see (post a screen capture or two) then we can know for sure what to dig into. Good Luck!
3 件のコメント
4SNS/1/C0000008: TP0P--124
T= Temperature
P= Power Bus.
*0P= *zero (is not O)
Rene Velazquez さんによる
I have the same AHT error code.. any solution?
Did you replace the DC supply Board or the SATA cable?
Any other solution found?
My MBP is A1425 Macbook Pro 13 retina i5 120gb SolidDrive.
Same error 4SNS/1/C0000008: T POP--124
