Replace Pismo screen witm a Lombard Screen
Can I replace the screen in my M7572 Pismo with the defective LCD screen from a M5343 Lombard?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Yes the Pismo and the Lombard use the same LCD panel. The only difference is that the Lombard doesn't have the airport antenna so you'll have to transfert the antenna from the Pismo display to the Lombard display.
このアンサーは役に立ちましたか?
+ Ralph
One other difference is the inverter board--they are different for the two computers. Just use the Pismo inverter with the Lombard panel and you will be fine. The included link explains the difference. Ralph
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,450
1件のコメント
Why would you use a defective LCD as a replacement?
Kyle Wiens さんによる
