メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
New screen / glass, touch not working 100%.
Good Day All,
I had ordered a new front glass replacement which came with the LCD and digitizer etc, I got this on my phone without any issues, the screen works 100%, however, the touch screen doesn't appear to be functioning 100%.
I opened the notes app and tried typing each letter of the alphabet, I had difficulty tapping on "H" and "N" and could not hit at all "J" and "U". If you look at the keyboard these keys are all in the same vicinity from top to bottom on the screen. I am wondering if I maybe didn't put down the cable all the way on the motherboard? Or if I got a bad screen?
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
ベストアンサー
Either is a possibility. Easy enough to simply make sure the digitizer cable, closest to camera of the two screen flex connectors, is perfectly in place. If the digitizer is faulty, then when you replace the screen again with a new one, be very careful with the digitizer flex, as it is very vulnerable to damage during installation.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
buy original screens for replacement, there is a lot of crap screens floating around out there. here is a info graphic on how to tell the difference.
http://www.syncedrepairs.co.nz/blog/orig...
fixit sell good quality. avoid eBay.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Phone screen crack
You can send me trick
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Darren Peck さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 117
