メインコンテンツにスキップ
2.3L 4cyl or 3.0L V6, 6th Generation
418回答 すべてを表示
What can I do my Honda is running on 3 cylinders
a honda repair shop said i would also have to have a new computer part so that the car will send gas to the fuel injection. The also suggested that it would be smarter to get a new engine then to have it rebuilt. Ive only owned the car for a year and a half and now i might as well see what i can get from junking it, great.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Marlene, what engine size does your Honda have and how many miles do you have on it? Have you tried to get a print out of the on board diagnostics (OBD)scan?
さんによる
Its a vtec 2.3L 4 cyclinder. No I do not have a print out. But il enquire into one. The want 500 to 600 to put a used computer part then they have to reprogram it to except the new computer piece just so my car will allow the gas to go to the fuel injection
さんによる
コメントを追加
1 件の回答
選択されたソリューション
Marlene,
Change the spark plugs, change the plug wires.
If there is fuel getting to the other three injectors, perhaps you have a bad injector so you can remove and clean or change that.
Start with the inexpensive stuff and work your way out to the more expensive. I'll bet you can find a used ECM on ebay or at a local junk yard for under $80.
Just to add to this, I was right about ebay. Here is an ECU for$69 or best offer and there are plenty more where that came from.
The location of the ECM/PCM is in the center console, under the radio. As you can see from this PDF on page 2.
Good luck,
please let us know,
Frank
このアンサーは役に立ちましたか?
スコア 1
コメント:
thank you Frank . i posted another question if you have time please review, you probably already answered it but if not any information will be greatly appreciated
さんによる
コメントを追加
回答を追加する
Marlene さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 5,507
