MacBook Pro A1278 starts, apple logo appears then shuts down
My wife has a MacBook Pro a 1278 model that will not boot up or turn on. I'm not certain of the exact version of 1278 but the serial number is: W80226HJATM
When I press the power button I hear the fans start to spin, the screen lights up gray, the Apple logo appears, the progress bar on the The bottom blinks twice while the time dial spins one revolution then the screen goes black and the computer turns off.
I have searched through the forums to find anything that is applies as the system does not hang in eternity,blink on and off or sit spinning -- it starts the boot sequence then just crashes. It has worked mostly fine for a long while, nothing spilled that i am aware of, battery seems good and the problem exists whether it's plugged in or on battery.
I tried command S to diagnose as seen in another post but honestly don't know enough about macs to see what is out of the ordinary as it seems to be a standard boot log. At the end it prompts me to type exit to continue the boot Which I did and the following lines appeared:
KEXT loading now disabled
KEXT unloading now disabled
KEXT autounloading now disabled
Kernel requests now disabled
Can't Get KEXTD port
Syncing disks… Killing all processes
Continuing
Done
CPU halted
Airport: link down on space. Space reason 8 (disassociated because station leaving)
I managed to take a photo of the previous results I just typed above (before it shut down again) but not certain if there may have been more lines just before it died.
I've read some mention of resetting the smc but can't find any details how to do that.
we will go to our storage locker this afternoon to retrieve the boot disks but not certain what to look for or do when we try to boot off of them.
Thanks for any and all assistance.
Best regards,
-David
この質問は役に立ちましたか?
Early 2010 MBP 13” (A1278) with similar “glitches.”
Problem: MBP is turned on without opening any programs but letting 4-7 minutes transpire, move the mouse via the track pad & “pinwheel” shows up and all programs stop responding. Can’t even use the normal shut down.
Happens whether you’re on battery power or a/c power supply.
Restart and retry, within the 4-7 minute programs stop responding and “pinwheel” comes up and nothing works.
I upgraded memory from 4GB to 8GB
Upgraded to a SSD hard drive, reformatted and Mac OS reinstalled
Changed Main Logic Board
Changed battery (original was 83 months old)
Reformatted and reinstalled several times with removal & full erasing & reformatting of the SSD drive
Thought it was the trackpad, started it without touching the track pad & keyboard & used an external mouse. I thought maybe solved… NOT Solved!
I’m about to retry original memory and reformatting of the SSD drive.
Any more suggestions?
Daniel Jansen さんによる
