My samsung won't charge, and isn't the battery's fault.
My phone was working fine, and charging fine, but when i woke up in the morning and went to check my phone the battery was at 35%. I unplugged my phone, and then plugged it back in. I waited a couple minutes and then when i checked it, it still wasn't charging. I took my battery out and put it back in after 15 min, and tried again... still nothing. So i took the battery out again and took the battery out of my cousins phone (Same exact phone,) and it still wouldn't charge. I tried plugging his phone in with my battery and it worked fine. So, what should i do? Also if i do need a repair, around how much would it cost? Thanks everyone!
この質問は役に立ちましたか?
Yeah, mine stopped being able to charge only a few nights ago, and I have bought a replacement battery, and still nothing. I have used someone elses charger that works fine for the same model of their phone. I cleaned out some lint with a toothpick, and still nothing.
Holly Halestrap さんによる
I just recently got a new Samsung and it won't charge and I just got a new battery for it...any suggestions?
Chase Davis さんによる
My Samsung S3 suddenly stopped taking a charge. The lightening bolt was on but the battery level was decreasing! Eventually it went down to 9%. I searched online: changed chargers, changed cables, gently cleaned and blew air in the female contact, changed batteries...nothing. Then I tried charging from my laptop and its working. Great. But now what when I want to charge from the wall outlet again?
Ralph Rey さんによる
I kept surfing for solutions and came to this one by Jens Persson. He said ...
"Solution:
-Turn the phone off
-Remove the battery
-Wait 10 seconds
-Plug in the charger
-Insert the battery
-Turn on the phone (in my case, just held down the power key for a few seconds then it showed charging, finally!)"
Thanks Jens Persson, that solutions worked perfectly...I had already tried everything else to no avail but that method worked!
Ralph Rey さんによる
Thank you, Jens and Ralph. This method works a treat. Annie R.
annierizk さんによる
37件以上のコメントを表示
