Screen failing intermittently - how to determine fault?
This Macbook Pro A1260 sn W8839008YJY has developed a fault where the screen goes black. Everything else is working normally, even the backlight / brightness keys can be seen to boost the 'black' up and down. It's probably the common fault with the GPU, I realise, but I'm wondering if there is any way of narrowing it down further in case its just an inverter or data cable, or even the logic board. The nearest Apple Store is quite a way off and Apple won't take it back via courier for diagnosis.
この質問は役に立ちましたか?
1件のコメント
When it fails can you still discern the desktop?
mayer さんによる
