My display panel is broken
I have an apple cinema display 24 inch.
I asked apple to repair it. They said the lcd panel is broken and that replacing that would cost 700 euro.
What lcd panel does the display have?
Thanks.
この質問は役に立ちましたか?
Thanks.
この質問は役に立ちましたか?
Lukas Guy, I believe that Apple uses a couple of different manufacturers for the monitor. The part number for the LCD is 661-4822 and the easiest way to verify that is by taking a look at the sticker on the back side of the panel. It is most likely a LG-Philips LM240WU6-SDA1, replacement cost around $400. Hope this helps, good luck.
このアンサーは役に立ちましたか?
Many thanks.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 856
