メインコンテンツにスキップ
When resting hands on side of trackpad, machine "freaks out"...
Can you help with a suggestion on what I can do to repair/"jimmy" my wife's MBP that, when she rests her hands to the left and right of the track pad, the machine seems to have a mind of its own. It's almost like there is a short with something right along the front edge. When I use it, I normally don't rest my hands, and lean the laptop in a different direction and it doesn't do it for me, but for her, it is nearly un-usable. I think I'm going to take it apart and have a look, but I don't know what to have a look for!!
When I press with light to moderate pressure, the cursor will jump, or a web site will page forward or back, or go to a favorite not even chosen that day.
Weird....
Any help avoiding buying a new one would be greatly appreciated. Otherwise, the machine's a champ!
Thanks
Tim
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
選択されたソリューション
Well...I think I figured it out. I recently replaced the battery with a knock off (not that that matters necessarily) and...it is warped slightly. After I completely took the thing apart and checked everything as suggested and blew off the dust, I left the battery out. With the battery out, the computer worked like a champ, and with the old original battery installed, it worked fine. I guess all I will need to do is get a new battery...
Thanks for the suggestion.
TIm
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
that is really bad - those lipo batteries are dangerous
さんによる
コメントを追加
check the track pad connections and the ribbon cables
here is the guide to remove the topcase
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
tdrehm さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 989
