メインコンテンツにスキップ
The T-Mobile G1 is the first smartphone to be marketed running the mobile Android operating system. Released in September 2008.
6回答 すべてを表示
Why does my camera/camcorder application force close?
I have rooted G1 running the latest Cyanogen 4.2.3.1. Unfortunately, my camera/camcorder app force closes and refuses to open. I have wiped, reformated the SD, restored to stock G1 ROM, even went as far as trying another ROM thats not Cyanogen (*GASP*), but everytime it force closes. I am thinking it might be a hardware problem, but I'm not sure. Help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
5 件のコメント
Are you running 1.5 or 1.6?
さんによる
I'm running CyanogenMod 4.2.5 which is based off of Donut 1.6.
さんによる
Normally this should be asked as a comment, but I'll hold off on down-voting you since you don't have the rep for commenting.
さんによる
sorry, i'm new, just got the code today, and don't understand this system entirely
さんによる
try reheating the i.c around the camera,i repair phones fyi
さんによる
コメントを追加
5件の回答
最も参考になった回答
This intrigued me so I went into study mode. All I can say is I do not have an answer. The cam force closes even when phone is restored to T-mob stock configuration?
Help per my reading:
1. http://twitter.com/cyanogen
2. http://wiki.cyanogenmod.com/index.php/Ma...
3. http://forum.xda-developers.com/showthre...
good luck.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
The cam does force close when the phone is restored to stock configuration. I have a feeling that its a hardware related issue at this point.
さんによる
コメントを追加
I'd assume then its a cyanogen bug, the latest ROM is not 100% compatible with 1.6, try a complete restore to the original rom and it should probably work.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
it sounds like it can't find the files in order to run
check and see if you accidentally moved or deleted some of the files
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
update software of camera
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
After clicking images, images are shown reverse
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Walter Galan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 7,550
