メインコンテンツにスキップ
2013年11月22日に発売されたMicrosoftの第三世代のXbox ゲームコンソールです。
727回答 すべてを表示
Is it easier to replace the internal drive than Ps4?
Can the drive be easily replaced that PS 4 ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
6件の回答
ベストアンサー
Just wanted to chime in here and say that Microsoft has made this very difficult for a professional to do and all but impossible for the DIY user. Especially if your old hard drive is faulty and you can't get the files off of it.
In general (IMO) if the hard drive in your Xbox One goes out you might as well either send it to Microsoft or just go buy a new one.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Take a look at IGN's full review of the PS4, they actually replace their hard drive with a 1TB unit and there is even a video showing you how to do it.
Here is the link http://uk.ign.com/articles/2013/11/13/pl...
Cheers.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
From the initial look, it looks like it will be easier to replace the PS4 HHD. But that doens't mean that either system will recognize the new HHD.
Xbox One Teardown
PlayStation 4の分解
PlayStation 4の画像
ガイド
PlayStation 4の分解
難易度:
中レベル
Xbox Oneの画像
ガイド
Xbox One Teardown
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Microsoft claims that hard drive is non-replaceable but there is a teardown method on this site that shows that it is more replaceable than they claimed. However, it require the user open the console completely which voids the warranty and I'm sure that the console won't work correctly if it is replaced so I wouldn't take any chances trying to do so. PS4's hard drive replacement is a lot more user friendly. All you have to is slide out the shiny black part on top of the PS4 and unscrew a couple of screws and slide the old hard drive out. Also, be sure to have the new PS4 firmware on a flash drive to load into the console so that it will work as soon as you reboot it. This process takes about 5 minutes depending on internet speed. Hope this helps.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Too be blunt and to the point here are the facts with some speculation. (speculation "*")
Xbox one:
1: Drive is not as simple to remove compared to the PS4.
2: Drive may have a proprietary file system*
3: Removing the drive will void warranty.
PS4:
1: Drive is simple to remove and replace, Only 1 screw needs removing.
a: Can be upgraded to whatever size you desire
b: supports SSD (slight improved loading times)
2: No proprietary file system, Just P&P
3: Will not void warranty
hope this clears things up.
happy holidays and happy gaming
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
not even close... i bricked my xbox. lol
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sanket さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,235
