メインコンテンツにスキップ
HPデスクトップ用の修理ガイドです。
349回答 すべてを表示
XP Media Center system recovery
I performed an XP full recovery on my PC now it freezes up at the XP logo and says please wait....I have waited for 10 hours. Then I tried a Hive Load/unload.....same thing! HELP!!!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
ベストアンサー
Are you using the HP recovery disk for your computer? If not you may be having driver problems. Did the recovery complete and now it won't boot or did it hang during install. What model computer do you have? With a little more info we can help you better. Ralph
Here is a cnet article on your problem. Ralph
http://forums.cnet.com/5208-6142_102-0.h...
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
I have a HP Media center Pc m470n. The recovery completed after installing the 10 dvds Hp sent me when I had to do this 2 years ago. It hangs up @ the windows xp logo and says please wait...i have waited up to 10 hours!
さんによる
Please look carefully at your install media--what you describe sounds like a corrupted file. Are their any scratches or other problems with your media? Ralph
さんによる
No, no scratches...I even cleaned them and tried it again...still waiting!
さんによる
How do I run a system diagnostic? The problem started when my CD & DVD driver disappeared and tried to reload it..one thing led to another...
さんによる
have you tried running a system diagnostics? why is it you were performing a recovery in the first place?
さんによる
コメントを追加
maybe this could help.
try it and let us know if it worked
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Ah, I see.
FYI there is a fix for the "missing" CD rom drive you encountered.
Was the recovery you ran off of your CD's or off of the recovery partition?
Running a diagnostics would consist of running a hard drive test & memory test for the basic stuff.
I would recommend Hitachi's Drive Fitness Test and also MemTest 86+ for Hard Drive testing & Memory testing. You would need to google these and download the .ISO, burn the image to a disc, and then boot off of the disc's. If you would like assistance with this we can help.
Thanks
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i tried to clean up my disc and some how deleeted windows completly ,i also download norton protection plan
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
what do you want me add
さんによる
What's your question?
さんによる
コメントを追加
回答を追加する
Toytalk さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,816
