Where are the spark plugs in a Vauxhall Corsa?
please tell me were thay are,vauxhall corsa
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I can link you to a thread here that seems to answer the problem.
Here is a excerpt:
Look at the front of the chrome plate.
Follow the front edge along to the right.
Look down a bit into the engine bay, and a little more to the right.
There should be some leads there that seem to come from towards the front,bottom, right-hand side of the block and head up and under the right edge of the chrome plate.
I would guess that's the HT leads.
Thanks to "Rob H" from that thread for that.
Let us know... Frank
このアンサーは役に立ちましたか?
+ Ralph
year/model/engine ? (they are on the streets since '82)
sure - i could guess - but they under the cover in the center of the engine top
but look at the distributor cap - (mostly on the right side) - there are 3 or 4 cables (depending on the engine) goning to the engine - at the end of the cables are the spark plugs
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 11
今までの合計 2,420
