メインコンテンツにスキップ
iMac Intel 27インチ EMC 2309 (Late 2009, Core 2 Duo 3.06もしくは3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHzもしくは Core i7 2.8 GHz) ID iMac11,1
467回答 すべてを表示
Pins on cpu holder (part U100) look bent, can this be fixed?
I bought a dead 27" Imac i5 EMC 2374 to try and fix, I may have found another problem with the computer, I need to know if the pins on the cpu cradle / holder should look like they do (image attached) or whether they are supposed to be all uniform.
is it possible to either replace the part (u100) or bend them carefully back into place with a needle?
any advice appreciated
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
you didn't get the image attached
さんによる
コメントを追加
2件の回答
ベストアンサー
I managed to use a scalpel and high-res images to view and bend all the pins back to their original position. 2 of the pins were at a slight angle, 1 of the pins was bent right back and i had to bend 2 normal pins to get back at it. after that i adjusted them all to original position. Mac functions normally after that. not bad for a $20 "dead" imac purchase ^^
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
When I've run across this I use a pair of mosquito hemostats to straighten them and then finish by carefully and gently inserting it. http://cdn.opentip.com/Home-Kitchen/Mosq...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Matt Rowlands さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 935
