Can Nexus 5 use battery from LG G2?
Hello,
Nexus 5 and LG G2 are very similar. There is a good chance their batteries are interchangeable.
If so, that would make it a cheap upgrade to 3000mAh for Nexus 5.
Thank you,
Sergey
この質問は役に立ちましたか?
Hello,
Thank you,
Sergey
この質問は役に立ちましたか?
Hi Sergey, thanks for the tip! I looked into it a bit, and it looks like the batteries have incompatible connections.
From xda-developers forum, the LG G2's battery has its connection on the top left of the battery:
From our teardown, the Nexus 5 battery connection is on the top right:
このアンサーは役に立ちましたか?
Connector is easily moddable. But the real issue is that BL-T7 is 7mm longer - won't fit anyhow. Thank you!
how about the lg g flex battery? looks like the connector is on the same side as the nexus 5 battery...
このアンサーは役に立ちましたか?
Would someone tell us the dimensions of the nexus 5 battery and the dimensions of LG G2 battery?
このアンサーは役に立ちましたか?
You can see it here http://forum.xda-developers.com/showthre...
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 17,889
This question was migrated from http://meta.ifixit.com/Answers.
iRobot さんによる
