How do you clean, or repair a mousepad?
The mousepad is slow or non-responsive.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Take a hard piece of thin broken plastic with a point and run it around the mouse seam to dislodge anything that may be hindering its operation. Go under the Apple in the upper left hand corner to System Preferences - Hardware - trackpad and adjust the tracking speed
このアンサーは役に立ちましたか?
two ways to fix: unscrew the bottom, remove the ball and take an eraser from a pencil and clean the contacts with it making sure to blow out the eraser particles, second fix, throw it away and buy a cheap laser mouse, it'll work much better.
このアンサーは役に立ちましたか?
mousepad not mouse
Usually called trackpad. Would be nice if people be more verbose with their questions.
The speed of the mousepad depends on many factors:
The type of desk it's being used on;
The wages of the worker using it;
The atmosphere in the office.
If you can solve all these you will have a fast, reliable mousepad...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,175
1件のコメント
its the mouse ribbon
mascorroirma さんによる
