メインコンテンツにスキップ
モデル番号A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 プロセッサ
329回答 すべてを表示
Can I upgrade CPU from i5 to i7
Hi, we have a iMac 27-Inch 2012 model which can run really slow from time to time - especially when we have alot of programs open.
The machine has 16GB ram, a 2.9GHz Intel Core i5 processor and is running OSX X 10.8.4.
The question I had really was, is it possible to install an i7 processor in it? Would I need to upgrade any other equipment such as the fan etc. Which processor would directly fit into my machine?
Any help would be appreciated as this machine is beginning to drive us mad!
Thank you
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
ベストアンサー
I think you need to re-direct your question on how to solve your problem Vs upgrading the hardware. Clearly you spent the effort on getting the max RAM and the i5 is not a slouch of a CPU! With the proper care & feeding your system should be singing!
Systems can bog down for many reasons not having enough RAM or HD space is the most common. Here you have enough RAM, but do you have enough free space on your HD and have you been good about defragmenting it. Over the course of time the drive gets fragmented while the Apps & Data can get into trouble the OS it's self does as well (even if you have a lot of RAM).
I would start off creating a external boot up drive HD or thumb drive so you can boot up under it. I would also make sure I have a good backup of what I currently have on my internal HD before I proceed to the next step here
Next you want to boot up under the external drive and run Apples' Disk Utility program to repair the drive and to repair permissions. See if that solves things first.
If repairing the disk with Disk utility didn't help you'll need to get a defragmentation program, I would recommend getting Drive Genus there are others which can be used as well. Using it you should be able to see how bad your disk is fragmented and can de-freagment the drive. That should make a big improvement.
If the drive is not badly fragmented you may have some apps running in background that are misbehaving. Use Apples' Activity Monitor to see what is chewing up all of the CPU cycles. Google the files name to see what it is or if you can identify what app it belongs to.
Of course I assume you have made sure you have maintained your OS & apps here making sure you have them updated with the latest version and/or updates. That you have a good antivirus app running and have the latest definition files for it. If not you may want to start here.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
New SSD drive and put the operating system on it with a new fresh clean install.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Probably you wont be able to do this because apart from processor there also CPU buses which works in conjunction with specified processor. So an i7 processor might work with different logic board architecture. But the best way to double check this thing is to download and read the service manual. On the other hand you machine`s specs are pretty good and the slow down issue can might be something else like heating some OS problem so you can try first by restoring it to factory setting but if the problem still persist then go for a warranty claim if you have.
このアンサーは役に立ちましたか?
スコア -2
2 件のコメント:
Would it give me such information in the service manual?
さんによる
Pritpal, no it will not.
さんによる
コメントを追加
回答を追加する
Pritpal さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,415
