メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
271回答 すべてを表示
17" iMac 1.83 with lines on screen
I have an Intel core duo imac g5 17" 1.83 and it has a built in cam. I'm confused as to what model of lcd is used to replace my lcd, as it has the ever so common and annoying lines in it. I also see 2105 at the bottom of the stand. Which models of screens (I presume must be with isight?) can be used to replace mine?
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメント:
You do not have a G5. It is an Intel processor machine.
Apple iMac "Core Duo" 2.0 20-Inch Specs
Identifiers: Early 2006 - MA200LL - iMac4,1 - A1174 - 2105
さんによる
コメントを追加
1 件の回答
選択されたソリューション
You will have to dismantle the machine to replace the screen. On the back of the screen is the manufacturers ID number. With this number and Google Shopping you should be able to find a replacement or compatible screen.
If this Answer is helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
スコア 2
コメント:
Thank you machead3. I'll give it a try.. never disasembled it before but will give it the old college try. I'm just wondering if it should be specified with isight and als.. which I assume is correct.
さんによる
To get you to your correct machine please give us the last three figures of your serial number located on the bottom of your stand. I think I gave you the 20" machine instead of the 17".
さんによる
This is an advanced DIY repair.Study the guide before you start, obtain the proper tools, keep all parts well identified. You are going to replace the LCD screen only. The camera will be reused (they are separate parts.
さんによる
Ok thanks machead3.. and the serial number is W860516SU2N mayer. It's the 17" model, is that the correct serial number you were looking for? I think there's only one serial on this machine.
さんによる
コメントを追加
回答を追加する
David Sutton さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 750
