メインコンテンツにスキップ
Laptops manufactured by Toshiba.
1030の回答 すべて表示
vertical lines across screeen of notebook toshiba qosmio
The screen of the desktop is crossed by a number (exactly 14) of vertical lines large about 1 millimeter of different colors.The device works well but the vision with those lines troubles me. Agostino Torre
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
iPhoneのバッテリーキット
Only $29.99
Buy Now
iPhoneのバッテリーキット
Only $29.99
Buy Now
3回答
選択されたソリューション
sounds not that great - but let's start with plugging the qosmio to an external monitor to rule the graphics card out.
here is a great comparsion of screen failures - but i think you's is example 2 with more lines.
here are a few guides for the qosmio's
この回答は役に立ちましたか?
スコア 1
コメントを追加
This happened to a friend of mine. Try lightly twisting the display frame. If the number of vertical lines changes or if some disappear and new ones appear then you will have to replace the LCD screen.
この回答は役に立ちましたか?
スコア 1
コメントを追加
The graphics chip on the X505 series and a few others tend to overheat and this causes the solder joints on the motherboard to crack and fail. New motherboards are available on ebay. There are also repair services to reflow the solder joints. You might even be able to repair it yourself with a heatgun like people do with RRoD Xboxes but that's probably above your skill level.
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
agostino さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 2,309
