Which glue could I use to fix the front panel?
i want to repair my ipad but i don't know which glue do i use, can i use the common white one?
You shouldn't need to use glue on your iPad repair. There should be adhesive that comes with the repair kit that you buy.
Here's a picture of the adhesive map for the iPad 4
Here's another picture without the map.
If the adhesive doesn't hold the screen down all the way – sometimes this happens if the adhesive is poor quality – you will want to use super gel. You can find it on Amazon here
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 238
