Why does my horn not work?
I have had my horn replaced and it lasted for about 1 year and now it once again does not work. I would like to do it myself now and not pay someone again to do a bad job. Where is the horn located and the associated wiring (I checked the circuits and relays and they're fine)? How is it mounted, replaced, and wired? 1998 Jeep Grand Cherokee - Inline 6 motor
この質問は役に立ちましたか?
3 件のコメント
oldturkey03, thanks for writing back! I did not check the physical wires (as I did not know where they were) but I did make sure the fuse was not blown and the relay was securely in place. The horn does not work when I press the button on the wheel or beep when I use the clicker to lock the doors (as it normally should). My horn had been working up until recently, so before I replace the horn and/or relay I wanted to make sure none of the wires fell out. I say this because when I had it replaced it sounded fine (albeit the horn was not from a Jeep) but as time went on I noticed that the sound quantity and quality has been decreasing; and now it doesn't work at all. However, I would love to replace it with a horn that was actually from a Jeep if I can find one for a good price. Thank you for the diagram, where did you find it?
Michael Kaminsky さんによる
Thank you for accepting my answer. The diagram comes from the service manual. Email me if you could use it. My email address is in my profile;-)
oldturkey03 さんによる
my horn on my 09 wrangler doesn't work. where would I find the relay for that?
Mike さんによる
