3 quarters of the screen Black with bars!
Hello,
I am trying to identify the problem. Is it the LCD or could it be something else?
It has never fallen and the "touch" works even on the black side!
Thank you
この質問は役に立ちましたか?
Hello,
Thank you
この質問は役に立ちましたか?
Looks like your dropped or banged your iPad so the LCD and logic connections along the edge of the screen got damaged. You'll need a new LCD panel.
このアンサーは役に立ちましたか?
Try replacing the lcd data cable
It's cheep and usually 99% of your screen malfunctions.
Good luck
このアンサーは役に立ちましたか?
Not likely the cable, given the visible symptoms. If it were the cable then the entire screen would look a mess not just a part of it.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 915
