when I turn my laptop on the screen turns white
when i go and turn my laptop on the screen turns white
You can fix this problem by performing a system restore, therefore you can adapt following steps to run this process:
Open start menu click run and then type cmd to open command prompt.
Type CD.. to make c:\ only.
Type CD windows then CD System32 and then restore.
After once you find yourself in c:\ windows\system32\restore>
Then type restrui.exe press enter.
Once the system restore window open then click next to select any available restore point.
This process shall take couple of minutes to perform restore and please make sure that once
this process started it wont be reversible and neither you will lose any personal data.
Other way to perform system restore is to open safe mode by clicking F8 on start-up and
check safe mode option then further a dialogue box will open to ask for system restore and
then follow the above steps. Thanks
このアンサーは役に立ちましたか?
hi,
im unable to reach restore after sytem32..
the message shown:
C:\WINDOWS\system32\resotre
'restore' is not recognized as an internal or external command,
operable program or batch file.
Need your advice on this..
thank you in advance.
and how do you do this if the screen is white...lol
By using the external monitor
yes, by using external monitor, plug the blue head cable into laptop.
No No No you run cd c:\ windows\system32\restore>
and type restrui.exe
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 27,061
Connect an external monitor to your laptop and see what it displays. The white screen is your backlight, you just do not receive any data. This could be because of a bad video card or a bad LVDS cable. Try the external monitor and let us know.
oldturkey03 さんによる
Connecting external monitor brought the regular display back to the laptop screen.
Acer Aspire E15
AB D さんによる
i face the same problem (white screen) and bought new led and replace them, it is ok for few weeks but turning back to white again...(acer) how to fix it
Zamzuree Abdul Halim さんによる
