Problems reattaching ZIF connectors
Hello and thanks for any suggestions anyone can give.
I'm putting back together an iPad 3 after replacing the battery and front panel. The ZIF connector for the headphone jack cable is proving to be a problem however. I can't get it all the way plugged back in to the white lines that are on the cable, and having tested it out (having replaced all the other ZIF connectors and turned it on), the headphones are not working.
So my question is are there any tips and tricks for getting these ZIF connectors reattached? I don't want to damage the cable, it's so delicate, and yet for the life of me I can't get it pushed all the way back into the port.
2 件のコメント
if it's anything like other zif connectors it shouldn't go all the way up to the white line
pollytintop さんによる
Actually commentary states the ZIF connector must be inserted slightly PAST white line. And they were this way before disassembly. Thankfully both the screen ZIF and the digitizer ZIF are functioning with connector still with white line visible. But the Audio cable isn't.
earthvital さんによる
