モデル番号A1225 / Early 2009 / 2.66, 2.93もしくは3.06 GHz Core 2 Duoプロセッサ
173の回答 すべて表示
My iMac does not start up, LED#1 not on
all the sudden my iMAc did show no reaction at all. No reaction to the pressing of the power on botton. No noise etc.
I brought my iMac for diagnostic to an authorized Apple dealer/repair center for diagnosis. Their result was that the logic board needs to be replaced. I ordered a used and tested logic board for my iMac model.
After replacing the logic board still the same symptoms. I checked the LEDs. Even #1 does not light up. Unfortunately I trusted the diagnosis of the apple center and did not check the LEDs with my old logic board.
my questions:
1.) Could be even the replacement logic board be defect? Would need to have the similar defect..
2.) Is it the PSU? Is it worth to go down that route as LED#1 does not light up
3.) Is there anything else than the PSU which could cause this, except for the replacement logic board having the same defect
thanks for your help Axel
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
MacBook Battery 修理キット
最低価格 $69.99
Buy Now
最低価格 $69.99
Buy Now
1回答
選択されたソリューション
Answer #1 Yes - unknown - you didn't check the LEDs before so any answer would be speculation.
Answer #2 This seems to be your problem now - we have to start someplace.
LED Startup Sequence
LED #1 = Power available.
If no LED is visible:
• Verify AC source
• Verify known-good AC cable is connected
• Verify cable connection between AC inlet and power supply
• Verify cable connection between power supply and logic board
• Verify power supply
Answer #3 - reread Answer #2.
If this Answer is helpful please remember to return and mark it Accepted.
この回答は役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Axel さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 287
