Half screen not showing
I have problem with my screen half of it is only a shadow and show only the upper one.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I'd suspect a LCD failure but before buying a screen you could verify the LVDS (video) cable connection to the main board and to the LCD panel and if you have the Apple miniDVI to VGA/DVI adapter you could also connect the MB to an external monitor to check the GPU (graphic processor unit) but IMO you logic board should be good.
このアンサーは役に立ちましたか?
+ Ralph
thank you so much, i have connected thru miniDVI and shown no problem with the external monitor. anyway i will follow your advice and check the LVDS connection. By the way i have MacBook Pro 15" and rain spot shown on LCD. i resolved the problem by reformatting the system. Just additional information for all members. THANK YOU
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,680
