How do I diagnose which component is bad.
I was given this iphone 4 after the owner had recently taken it in to have the screen replaced. She said it worked for a day and then nothing. The repair man did not stand behind his work. when I plug it in to charge it a white apple lights up then disappears and continues to do so. I've taken it apart and checked all connections and check the battery at the connecter and its putting out 2.8 volts. I tried DFU mode but had no luck and since I'm not the original owner and it's been worked on already I can't fall back on the warranty. I don't know what to check next.
この質問は役に立ちましたか?
2 件のコメント
Problem solved. I cleaned both the battery connections and the dock connecter with electronic cleaner and plugged it into a A/C charger and all works now. Thanks oldturkey03 for your answer and also vanish172.
russell eyre さんによる
Excellent, great job. Best of luck to you
oldturkey03 さんによる
