How do you repair sony xperia v broken usb port? (pins broke off)
xperia v usb port
この質問は役に立ちましたか?
xperia v usb port
この質問は役に立ちましたか?
it's soldered to the motherboard..taking these phones apart is pretty standard, take a look at one of the other xperia guides and use that as a start. The part itself should also be standard across the range of sony xperia phones, so take a look on eBay/alibaba or whichever. You will need to be able to solder and desolder. this is one source of photo's which you could use for the teardown.
このアンサーは役に立ちましたか?
i have the same ploblem and i dont know how to fix it. i can´t find help, there should be meny many more with this problem.
keep searching!
dont give up!!
/ malin
このアンサーは役に立ちましたか?
Lookie what I found:
このアンサーは役に立ちましたか?
I have same problem with my sons xperia u. Is it easy to just slot this part in? Cant afford a new phone!
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 3,749
