メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
3272の回答 すべて表示
Problem with screen after trying to fix proximity sensor on iPhone 4
Hi there. First, this is my first time opening an iphone. I watched many videos and guides on how to take off the display and fix the proximity sensor. I used the technique with the scotch tape but it didn't work for me. I didn't actually used scotch tape but a clear tape. Maybe this is why the proximity sensor doesn't work. If anyone can also help me with that i would be greatful.
Anyway... after reassembled the iphone i noticed a big blue dot at the screen. See the picture here.
Is the screen damaged? Or did i connect something wrong?
Notice that before opening the iphone i used the same screen and it was working perfectly fine.
I also had a difficulty on reassembling the logic board. I think it's not perfectly positioned. Are there any detailed instruction on how to reassembe it correctly? Or a video?
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
This question was migrated from http://meta.ifixit.com/Answers.
による
it seems that the problem is actually from a logic board screw but i can't unscrew it. The screw guides has dissapeared becaused i used the wrong screw driver. Hope you understand what i mean. This is the screw i have problem unscrewing it.
http://d3nevzfk7ii3be.cloudfront.net/igi...
What should i do?
による
コメントを追加
iPhoneのバッテリーキット
Only $29.99
Buy Now
iPhoneのバッテリーキット
Only $29.99
Buy Now
1回答
最も参考になった回答
I usually take a sliver of black electrical tape to separate the sensors. I actually have some oem style foam pieces that perfectly fit in that upper part of the frame to prevent the issue you are having. You can find them on ebay.
That blue spot you have seems to be a pressure point. If I recall correctly, that's possibly one of the logic board screws. You may have accidentally put the wrong screw in the wrong place, possibly extending beyond the frame and pushing against the backside of the screen. If you're not familiar with organizing your screws and remembering where they're supposed to go, it can be very easy to mess up.
この回答は役に立ちましたか?
スコア 1
コメント:
I actually used an iphone 4 screw template for remembering where each screw goes.
Actually I had some problems with one screw. I could not tight it. I thing that's because I haven't positioned the motherboard correctly.
Can anyone record a video on how to position the logic board correctly on iPhone 4?
Please send a link of eBay item in a private message.
Thanks
による
コメントを追加
回答を追加する
christos さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 875
