メインコンテンツにスキップ
The HTC Desire HD is an Android smartphone by HTC Corporation.
26回答 すべてを表示
Won't turn on, so replaced motherboard but still won't turn on?
Hi,
HTC Desire HD won't turn on so I replaced the upper part of the motherboard and it still won't turn on.
I think it might be the battery, battery connector, or the charging port as no LED is showing when I plug the charger in?
I've tried to do the hard reset thing a couple of times (power button + volume down) and only once has it shown a red LED but that's all, no sound and screen didn't turn on (screen looks in good condition also).
Don't want to waste any more money buying parts that aren't needed as I already paid ~£20 for a new motherboard so was hoping you guys could help me :)
Also don't know the history of this phone as I bought it off ebay but the water indicators are still white so I don't think it's water damaged.
Thanks,
Brad
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
did u flash the OS after replacing motherboard...
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Can you explain what that is / how to do it? Sorry, I'm new to fixing phones
さんによる
firstly i should know whether ur phone showing any sign while charging..if not make sure that ur phone battery is not dead and power is passing in mother board...if it is done connect it to pc and check in HTC pc suite whether it is detected or not....hope we can fix it...good luck
さんによる
Thanks for the reply.
Phone is showing no sign while charging, no LED or anything. How can I check that battery isn't dead or power is passing through motherboard?
Thanks
さんによる
Check it with MULTIMETER
Your mobile battery have 3v - 5v DC
Place the battery in mobile and check the motherboard sockets whether voltage is varying or not..
If not check all the connections again..If nothing happens better you should take it to HTC support center.
Good Luck
さんによる
コメントを追加
回答を追加する
Brad さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 968
