メインコンテンツにスキップ
The T-Mobile G2 is a smartphone that features similar specifications to the HTC Desire and the HTC Desire HD but is a slider.
8回答 すべてを表示
Power button acts like it's being pressed.
The power button acts like it's being pressed when i'm using the phone, it always interrupts me, triggering the lock screen and context menu, but that's not all phone sometimes also acts like there's an headphone plug in even when there isn't, at times like these i can only hear caller through the loudspeaker, i have no idea what could be causing these issues, any help would be greatly appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
The power button problem sounds like a hardware fault with the power button and/or the ribbon it's connected to, and from a quick google it seems that power button issues are somewhat common with this model. Is it possible that any water/liquid penetrated the external case (the symptoms you report could happen if any of the switch contacts are randomly shorting this could happen, and water ingress could be one possible cause). There are some "self repair" videos on youtube (just search for "desire z self repair"), but they are not particularly easy..
e.g. http://www.youtube.com/watch?v=6UtNU8n0M...
Not sure what you meant by 'I can only hear caller through the loudspeaker' - that doesn't sound like a headphone problem at all (if headphone was plugged in, you would NOT hear the caller through the loudspeaker).
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Okwuanga Emmanuel さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 2,560
