iPhone 4 only charges when "OFF" after digitizer/screen repair
Hello, I have seen similar posts but I have yet to find a clear resolution.
I replaced a cracked screen/digitizer and now my iPhone 4 (ATT) does not charge or sync to itunes with cable. It does charge when the phone is completely off, although there is no sign of it actively doing so (like a charging icon).
I have ensured that all connections are clean, tight. I have tried doing a hard reset -- no fix. I can't restore as ITunes is not recognizing it.
Should I replace the dock connector? Battery? I have read elsewhere that this may not solve the problem. I have also read that this may be a problem with the VCC controller.
Has anyone with the exact same issue been able to find a solution? Thanks.
この質問は役に立ちましたか?
