Why won't my PS3 Super Slim turn on?
My PS3 Super Slim won't turn on. I press the power bottom at the console red light and makes the beep like normal then in a second the green light turn off and after that the ps3 won't do anything ...please help
You cant access the recovery menu if the ps3 wont even turn on...
このアンサーは役に立ちましたか?
you can keep the hardrive make a clone
first of all, if you are currently under warranty then stop fixing and start sending!!!
first get an external hard drive if you value any of your data!!! because the following will/can cause loss of game data/pics /music/vids. I recommend backing up your hard drive if at all possible through alternate source.
Turn off the PS3. Locate the PS3’s power button at the front of the unit. Touch and hold the power button until the power light becomes red.
Reset the PS3. Touch and hold the power button. The unit will power on and you will hear a beep. Continue to hold the power button and you will hear a second beep, indicating the video reset. Keep holding the power button down until you hear a third beep. The console will power off afterwards.
Activate the "Safe Mode" feature. Touch and hold the power button. Again, the unit will power on and you will hear a beep. Continue to hold the power button and again, you will hear a second beep for the video reset. Continue to hold the power button until you hear a quick double beep. Release the power button.
Using "Safe Mode." If you are successful in activating "Safe Mode," you will see the following message on screen: “Connect the controller using a USB cable and then press the PS button.” Follow the instructions on screen in order to enter "Safe Mode."
1. Restart System:
Ends safe mode and starts up the system normally.
2. Restore Default Settings=
Performs operations for [Restore Default Settings] on the PS3 Home Menu, and also deletes PlayStation®Network account information from the system.
If you sign in to PlayStation®Network after performing [Restore Default Settings], purchased games can be played without any additional operations.
Note that for downloaded (purchased) games, if you turn off the system before you sign in, the following error message will be displayed when the game is started, even if you turn on the system again and sign in:
To access this content, you must activate the system.
Go to [PlayStation®Network] > [Account Management] to activate this system. (80029514)
To access the content, go to [Account Management] to activate the system.
(Even if [This system is activated] is displayed, deactivate it and then activate it again.)
3. Restore File System=Attempts to repair all areas on the hard disk drive where files can be saved. Corrupted data may be erased if it cannot be recovered. (I recommend this 1st)
4. Rebuild Database=Deletes messages, playlists, changes made on [Information] screens, trimming information for pictures in [Photo], video thumbnails, video playback history and video resume information. (I recommend this 2nd)
5. Restore PS3 System=This corresponds to [Restore PS3 System] operation on the PS3 Home Menu (quick format). I recommend this as a last resort, this will make your ps3ss brand new per say, like it came out of the box, but I strongly recommend trying 3 and 4 first!!
6. System Update=Updates the PS3 system software (can only be done from storage media).
if you cant get into the safe mode, then might as well buy a new one because you will need another hdd!
Hope this helps, it has helped me fix several ps3's with similar problems.
このアンサーは役に立ちましたか?
you are my hero
the system is not even turning on how the !&&* am i supposed to do that.... and i have a ps3 super slim if you haven't notice the name of this post
How long does these steps usually take?
My ps3 stuck of red light and won’t turn on please any solution?
Try this. Turn off the system. Unplug it. Plug it back in. Attempt to turn on and watch the lights closely. If the red light turns green for a split second and then flashes a yellow light for a split second, and then blinks red, you have the Yellow Light of Death (YLOD). Just follow the instructions found on here for the YLOD repair.
このアンサーは役に立ちましたか?
Either the motherboard is bad or you need a new powersupply
このアンサーは役に立ちましたか?
best way to test maybe a ac tester
If you have recently dropped it and/or spilled anything on it that may be causing the problem.
このアンサーは役に立ちましたか?
My mother recently smashed mine on the post of my bed, she also broke TWO GRAND THEFT AUTO 5'S and a controller.
My PlayStation 3 won’t turn on even when I hold the power button down I wanna try to use it on the control
このアンサーは役に立ちましたか?
My ps3 is showing just red light, when I press the power button the red light stand still, which was suppose to show green, pls what would have course it mean is the power? Or the drive
このアンサーは役に立ちましたか?
I have same problem
Unplug the system for 30 MINUTES up to an HOUR... It should work after that...
このアンサーは役に立ちましたか?
Did not work.
I Want everybody stop wasting money!
I Fixed my PS3 by unplugging then replugging right after unplugging then waiting at least 5 minutes, after that you can turn on your PS3 system, you'll notice it's really silent , but after 15 minutes it'll sound normal, you turn it off you'll have the same problem again but you can fix it by keeping it on and playing then about 15 minutes mine was better and had the normal sound
If this didn't waste your money GIVE ME MONEY!
このアンサーは役に立ちましたか?
I can't keep my ps3 on for 15 min it turns back off long before that.
LOL brush I have same problem too bad Amazon is out of ps4's
I have the super slim with a 500GB HDD and I had the issue where the light was red and when pressed, it turned green for under a second then went off completely, as if it had been unplugged.
The short term resolution was to plug it back in (so the light was red) and then unplug it for about half an hour (maybe less I didn't really test) and then when you plug it back in it should just switch on, but you would have to do this each time you'd like to use it
Long term would be to have the red light active and then leave unplugged for half an hour then plug back in and boot into safe mode and select 'restore file system'. It told me it had to format the PS3 but I saw now visible changes when it loaded back on (I think it formatted the 12GB of storage that my PS3 came with) and then it would switch on and off as it used to.
このアンサーは役に立ちましたか?
Mine if plugged doesn't show any light if I press the button it will show white light and off how do i solve the problem
You’ll have to completely disassemble it all the way down until you can expose the CPU and GPU chip. Clean off the old dried up thermal paste off the chips and heat-sink and reapply your brand of choice. I’ve done this on my own PS3 as well as multiple laptops that did the same thing. Most boards have a temperature limit and will auto power down when the chips exceed the max temperature. It’s a safety measure design put into most boards so that they don’t self destruct.
このアンサーは役に立ちましたか?
I tried this and it work for me, it seems it is the power supply
このアンサーは役に立ちましたか?
このアンサーは役に立ちましたか?
It might also be your power supply. If you disassemble the power supply, there is a chance a roach might be shorting out one of your capacitors. I've seen it before.
Try adjusting the angle your PS3 is seated at. This kept mine on for about 20 more seconds. However, this was a pixel-perfect angle, down to the degree. This may give you enough time to fix the PS3. I ran out of luck after it powered down, though, and it seems like this can only happen on occasion.
このアンサーは役に立ちましたか?
My PS3 seemingly has the same problem yours does, by the way.
Same thing happened to me but I just held down my power button and it worked
このアンサーは役に立ちましたか?
I have to reset the graphics
If it's dead it could be the power button ribbon cable, I used to fix these and it was a common fault.
I on my super slim ps3 it showed green light and after some seconds if went off what is the problem please
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 31
過去 30 日: 143
今までの合計 124,553
13 件のコメント
Hey my PS3 doesn't start up it has a blinking red light,when I turn it on.it shows the green for two second then orange and then back to the blinking red light.please help
vusichron さんによる
Infamous Ylod
Alex Scharkley さんによる
I have the same problem i took it apart and cleaned it out but it still does the same thing i will power it on it stays on for 2 seconds and powers off i need answers plzz
Jaylen さんによる
Its not something you can fix on your own i had the same problem took to a guy who fixes ps3s and its either your power supply or graphics and the power supply circuit can't be fixed at leastthat's what he told me
Diggytygoo さんによる
hey iv been told by numerous people its either your hard drive or your motherboard
tkdkid13 さんによる
8件以上のコメントを表示
