メインコンテンツにスキップ
Mid 2010 Model A1278 / 2.4 もしくは 2.66 GHz Core 2 Duoプロセッサ
794回答 すべてを表示
Identifying water damaged IC on logic board
Some water spilled under a macbook pro and got inside around the fan exit. Now, it charges the battery but doesn't turn on, no fan, no sound. It does SMC reset (the charger light turns red and then back to green again) so I know keyboard and power button works (on/off pads on logic board didn't turn it on either). The battery is good. I opened it and found where the water got on logic board. It was very little water but it shorted one of the IC's. I cleaned all the residue but it didn't help. I might attempt to change/resolder that IC if possible. Can somebody identify it? It has a label KO384 OH4 626C. I circled it on the pictures. Thanks,
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Emre, that is reference designator Q7620 which is a RJK0384DPA - Silicon N Channel Power MOS FET with Schottky Barrier Diode High Speed Power Switching - Renesas Technology Corp. It is part of the CPU VTT(1.05V) supply circuit. The datasheet is available right here. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks :) I wonder if changing this part only will fix the problem.
さんによる
コメントを追加
回答を追加する
Emre さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,040
