Why does my battery not charge?
I have a new battery, a new battery charger and a new charging board. But the battery still will not charge.
will not take a charge (especially cheap ones from china).
If this answer is acceptable please return and mark it.
Good Luck,
N.
このアンサーは役に立ちましたか?
Hi,
I am a newby here, my MBP 15' (late 2011) did not charge when i was doing my project yesterday, the green light were disappeared, battery percentage dropped to 56%. I google the issue, I then realize that my battery is acting strange and please take a look at the MBP System Report stated as below: -
Manufacturer: SMP
Device Name: bq20z451
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 406
Hardware Revision: 2
Cell Revision: 158
Charge Information:
Charge Remaining (mAh): 469
Fully Charged: No
Charging: No
Full Charge Capacity (mAh): 6289
Health Information:
Cycle Count: 83
Condition: Normal
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 11040
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 10
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 10
Wake on AC Change: No
Wake on Clamshell Open: Yes
Wake on LAN: Yes
Current Power Source: Yes
Display Sleep Uses Dim: Yes
GPUSwitch: 2
PrioritizeNetworkReachabilityOverSleep: 0
Standby Delay: 4200
Standby Enabled: 0
Battery Power:
Display Sleep Timer (Minutes): 2
GPUSwitch: 2
Reduce Brightness: Yes
Standby Delay: 4200
Standby Enabled: 0
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Revision: 0x0000
Family: 0x0000
Serial Number: 0x00000000
Charging: No
I tried almost every mattered posted on the website such as SMC, reset PRAM but I still couldn't resolve the problem, after that my battery percentage went down to 7% and my battery is not charging!!! Is my battery died and needs to be replaced a new one? Any advise would be very much appreciated.
Thanks & regards
KL
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,580
Go to System Profiler look under power what does it say about the battery.
originalmachead さんによる
