メインコンテンツにスキップ
2012年3月16日に発売されたiPad Wi-Fi機能搭載の第3世代モデルです。モデル番号はA1416です。修理には温めて、慎重にこじ開ける作業が必須です。
154回答 すべてを表示
Top of the screen not working, digitizer or motherboard?
Early last year my Ipad was dropped an it cracked the screen. I took it in to a local repair shop and they replaced the glass. At that time I purchased a warranty. Last week the Ipad was dropped again causing another cracked screen. When I picked it up I noticed the top half of the screen was not responding to touch. They told me the unresponsive touchscreen was due to some damage to the motherboard and there is nothing they can do. They did offer to replace they Ipad under the terms of the warranty for an additional $200.
I am by no means and expert, but I would think that this is a digitizer problem (which is covered under the warranty) not damage to the motherboard.
Thanks for any help.
James
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -2
コメントを追加
2件の回答
ベストアンサー
It's hard to say, but it's one of the following:
1) Defective Digitizer - Area that's bad digitizer between the LCD and glass.
2) Board connector is bad - Since you said it dropped, it is possible that the connector damaged the board connection.
Was the digitizer cracked but functional in all spots before the repair? If so, then I would say 95% chance it's a bad digitizer replacement part or the board connector was damaged during replacement.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It had a very similar problem before the drop in another area of the screen. After talking to the guy at the repair shop the connection has been damaged. At this point I think I just have to live with the problem or pay for a replacement.
さんによる
コメントを追加
Chances are the top half of the digitizer cable came undone during the drop. You need to make sure both the top and bottom halves of the cable are in the port for the entire screen to work.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
James Crowther さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 15,515
