My screen is blinking
I have to push and pull the lcd until find a position to image appear.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sounds like you have damaged a cable... either the data display cable or the inverter cable.
That is not a hard DIY fix. Aquire the proper tools (any job is easier when you use the correct tool). Use the guide to remove the top case... inspect the cables for nicks/cuts, carefully moving the cable with a plastic/wooden tweezer or toothpick (to avoid shorting) can tell you which one is the problem... order a replacement an swap it out.
If this Answer is helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 81
