メインコンテンツにスキップ
モデル番号はA1040/10、15、20、30もしくは40GBハードドライブ/タッチホイールの上に4つの感知式LEDバックライトボタン
97回答 すべてを表示
Can't decide if the battery is dead or the HDD?
Hello,
I just found my old 3rd gen iPod and wanted to use it again.
I have the dreadful apple logo and folder with exclamation mark flashing after pluging it in the firewire charger.
I tried the diagnostic mode, and it doesn't seem to pass the HDD scan, I launched it and it stayed all lit up with just HDD scan on the screen for a while and started heating up. It's been 30 min and the test isn't over yet... but I remember when I stopped using my ipod 4 years ago I had issues with the battery.
Prior to the hdd scan I ran the A 2 D test for the battery but never got this type of reply which I found online when looking for the diagnostic mode. my ipod was charging during the test.
"Tests the iPod's power. Your results should look something like this: "3.7V 0X000000E2 CHG OK FW 1 BAT 1". The results will be different depending if your iPod is plugged into your computer, a wall outlet or is just running off battery power."
I have this on my screen
ADC test
ID 004A
BAT 00158
ACC 003FF
ACC2 000FF
Do you have any ideas what the issue could be?
I'd like it to work again but I am ready to replace one component so do you think the issue is battery related or the hdd?
Thank you very much for your help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
sergenteliver, just from the age of the iPod my recommendation would be to replace the battery for sure. Regardless of any error etc. It is absolutely past its life expectancy. the error itself points toward a bad hard drive. You could get an adapter so that you can test the hard drive as an external drive on your computer. It is possible that the drive has "gummed" up and is frozen. I use one of these adapters to test my drives. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
great thank you for your quick reply
I will start with the battery and take it from there.
さんによる
the fact that it is old and the battery is probably dead, does that explain why it doesn't show in iTunes?
さんによる
Not the age, but the battery and the HDD could be a cause for that. Also, do remember that this iPod model works really well with Firewire connections and that you need to have a Firewire charger to restore:-). It is a great model, and I prefer my 3rd gen over any iPod touch.
さんによる
I have a firewire charger! when apple still gave those when you bought an ipod ;)
so I can charge it, but to sync I only have usb on my macbook so I wasn't sur if that may be the issue. and yes it's a great gen that's why I would like to fix it
thanks again for your help
さんによる
For the sync your USB port will work :-) no issues with that at all.
さんによる
コメントを追加
回答を追加する
sergenteliver さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 372
