メインコンテンツにスキップ
Eighth generation of the Honda Civic.
58回答 すべてを表示
'06 Honda Civic stereo code?
I removed the battery in my 06 Honda civic, after I put the battery back my radio/stereo wouldn't work and it kept on asking for a code to put. can anyone help me out on what code I should put?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
4 件のコメント
Hi Josiah, I recommend you take a look at the guide on the below website:
http://www.freeradiocodes.com/brands/hon...
It will show you exactly how you can get a radio code for your Honda Civic for free.
さんによる
Yeah I had this samee issue actually a while back. You can get a radio code here: https://radiocodevault.com/honda
Hope it helps mate! :)
さんによる
hi
I need code for my Honda Civic 2007
I am in Saudia and i am unable to find the code :(
any body who can help me?
さんによる
hi
I am in Dubai and i am unable to find the code :( any body who can help me?
Tried several times the same solution on the https://radiocodevault.com/honda/ but it says VIN Invalid.
さんによる
コメントを追加
6件の回答
ベストアンサー
Josiah, give this a try:"
  1. Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)Turn car to ON II(radio powers up)
  2. Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)Turn radio off
  3. Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)
  4. Hold 1 & 6 buttons on radio
  5. Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)While still holding 1 & 6, turn radio on
  6. Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)Write down the 8digit number that should display
Call your Honda dealer and give them those numbers. Or just follow the directions on here. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
最も参考になった回答
I got my Civic’s radio code from this site: https://radiocodevault.com/honda/ its great, got my code in like.. an hour I think? It was sent straight to my email.
MUSIC FINALLY AGAIN! :DDD
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Donner moi le code pour la radio Honda civi 2006
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Many times there is a sticker on the left side of the glove compartment containing the radio code. Check there first, because sometimes the Honda dealer can charge you to look up the correct code.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Your radio code is unique to your radio, you will need your radios serial number in order to successfully generate a radio code. visit the below website which will explain how you can find out the serial number of your radio and also how you can generate a radio code for your honda civic.
Check it out here... http://freeradiounlocking.com/brands/hon...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Je veux le code pour ouvrir la radio de ma Honda civi 2006
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Josiah さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 62
過去 30 日: 242
今までの合計 49,398
