'06 Honda Civic stereo code?
I removed the battery in my 06 Honda civic, after I put the battery back my radio/stereo wouldn't work and it kept on asking for a code to put. can anyone help me out on what code I should put?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Josiah, give this a try:"
Call your Honda dealer and give them those numbers. Or just follow the directions on here. Hope this helps, good luck.
このアンサーは役に立ちましたか?
I got my Civic’s radio code from this site: https://radiocodevault.com/honda/ its great, got my code in like.. an hour I think? It was sent straight to my email.
MUSIC FINALLY AGAIN! :DDD
このアンサーは役に立ちましたか?
Many times there is a sticker on the left side of the glove compartment containing the radio code. Check there first, because sometimes the Honda dealer can charge you to look up the correct code.
このアンサーは役に立ちましたか?
Your radio code is unique to your radio, you will need your radios serial number in order to successfully generate a radio code. visit the below website which will explain how you can find out the serial number of your radio and also how you can generate a radio code for your honda civic.
Check it out here... http://freeradiounlocking.com/brands/hon...
このアンサーは役に立ちましたか?
過去 24時間: 6
過去 7 日: 52
過去 30 日: 255
今までの合計 50,065
4 件のコメント
Hi Josiah, I recommend you take a look at the guide on the below website:
http://www.freeradiocodes.com/brands/hon...
It will show you exactly how you can get a radio code for your Honda Civic for free.
josephmanu さんによる
Yeah I had this samee issue actually a while back. You can get a radio code here: https://radiocodevault.com/honda
Hope it helps mate! :)
James さんによる
hi
I need code for my Honda Civic 2007
I am in Saudia and i am unable to find the code :(
any body who can help me?
abdul_elaah さんによる
hi
I am in Dubai and i am unable to find the code :( any body who can help me?
Tried several times the same solution on the https://radiocodevault.com/honda/ but it says VIN Invalid.
salahuddinbutt.420 さんによる
