Car is over heating
Car over heats, but not consistantly. It will go weeks without overheating, then overheat two days in a row. I have changed the thermostat and the coolant is full.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Have you had the radiator flushed (may need to do this more than once)? Either you have some junk blocking the core and/or hoses. Lastly, your pump is going or your core is in trouble.
このアンサーは役に立ちましたか?
If it is intermittent I would suspect the radiator. It doesn't take long to blow a head gasket if the engine over heats so it's best to find the fix before it gets really costly. Jack
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 1,428
