メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
3278の回答 すべて表示
iPhone 4 backlight on, but no image?
My old iphone 4's sleep/wake button died, so i followed a friends advice and decided to try putting a small pieced of paper in between the button and contact. I followed ifixit's guide to install a new button, but instead of installing a new one, i merely took a small piece of paper and wedged it in between the button and contact. I tested it out before putting it back together and the button had decent feedback, so i preceded to put it back together. I cleaned all of the contact points with windex, dried them with a micro-fiber cloth and then used compressed air to make sure everything was dry and no particles were left. I was very gentle on the cables to maker sure I didn't break anything. I carefully put the logic board back in making sure not to damage the gold connector and I kept track of all the screws by laying them out on their assigned spaces on a diagram I drew up. After putting it all back together, I pressed the power button, but nothing happened the screen didn't light up or anything (no backlight), but after about a minute the phone buzzed and the backlight came on. Now when i press the sleep/wake button I can power cycle the phone a turn the screen on and off, but no image appears, just the backlight. I opened it back up and carefully cleaned the connectors with windex, but still nothing happens. I've restarted the phone, but to no avail. I also tried restoring via dfu but nothing happened. I got the phone to play music, and i could sync and backed it up with itunes so it must be a screen issue?
Problem: when i turn on my iphone 4, the screen stays completely black (no backlight) through the boot sequence, but then when iOS is actually loaded and the lock screen is supposed to come up only the backlight turns on and there is no image. This happened after sleep/wake button repair.
I also closely checked the logic board connectors for damage, but I did not see any (specifically the resistor right below the lcd connector)
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメント:
Why would you use windex thats crazy..
Try a hard reset
による
The ifixit guide said to use windex because its a good degreaser. Hard reset didn't work. Ive tried hard and soft resets, but The screen doesn't light up on boot (it's completely off) it only turns on once the device gets to the lock screen and then it just goes blank. I'll probably just take it to a certified tech.
による
コメントを追加
PCラップトップ用バッテリー
An easy fix for a big power boost.
ショップを見る
PCラップトップ用バッテリー
ショップを見る
1回答
選択されたソリューション
did you take the screen of to get the 2 screws out for the power button? or did you bent the flex cables? sounds to me your lcd is broken.
この回答は役に立ちましたか?
スコア 0
コメント:
I did exactly what the tutorial said, so I did not remove the LCD and I'm sure that was my error. I thought it seemed kinda bizarre to bend the cable to reach the screws, but I removed the screws at an angle to avoid putting pressure on the LCD and digitizer cables, but I'm sure the cables have gotten more brittle over the years so even the light bending was probably too much for them. Thanks for the response! I'll take it to a professional.
による
コメントを追加
回答を追加する
Dan さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 4,411
