What is the command for print screen on my MacBook air?
I need to know which command should I use to make a print screen.
Thank you.
この質問は役に立ちましたか?
Thank you.
この質問は役に立ちましたか?
このアンサーは役に立ちましたか?
Thank you very much for your help! :)
If you want to capture screenshots on Mac, you can use Command + Shift + 3, 4, or 5, depending on the types of screenshots you want to capture. Each key combination will do a separate function, e.g., capture a full screen or just a portion you choose.
For further guides of taking screenshots on your Mac, read this guide.
このアンサーは役に立ちましたか?
This was helpful but not detailed enough. I got this from Google too.
このアンサーは役に立ちましたか?
I had found a detailed article on this topic: Command to print Screen on my macbook
このアンサーは役に立ちましたか?
Thank you for the information . I will let you know how it turns out !
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 19,062
2 件のコメント
This question was migrated from http://meta.ifixit.com/Answers.
iRobot さんによる
It’s amazing that Snipping Tool for Mac can capture screen in irregular mode. http://wetechtuts.com/print-screen-snipp...
Rup Kumar さんによる
