メインコンテンツにスキップ
Model番号 A1225 / Mid 2007とEarly 2008 / 2.4, 2.8もしくは3.06 GHz Core 2 Duoプロセッサ
433回答 すべてを表示
iMac 24" will not power on (logicboard or power supply?)
I have a iMac 24" (A1225) which will not power on anymore.
power on button gives no responce.
Looking at the status LED's i have the following behaviour:
Power cord connected.
LED 1 is on.
pressing power on button,
LED 1+2+3 is on, fan starts running, then after 2-3 seconds all LEDS out.
iMac does noting. Also LED1 stays out.
After taking of the power cord en reconnecting it LED1 is on again and the whole sequence can be repeated.
Is this a power supply failure?
or a logic board failure?
Update
Unfortunately not.
it looks like this:
http://www.super-laptop-parts.com/apple-...
Update
Model MID 2007
Modelnr: A1225
EMC no: 2134
last digits of the serial nr: ZCT
Update
Update::
I had no boot chime.
Just the LED sequence as mentioned above.
I removed the videocard and now it is giving me the boot chime.
And it stays on !
So i think a new video card is the answer.
Can i put a GT130 card in this machine ??
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
What is the EMC number? What year is it?
さんによる
THIS or THIS post may assist you.
さんによる
Hello, I have the same problem, can you please tell me what was the fix? Thanks
さんによる
コメントを追加
3件の回答
ベストアンサー
Power supply defect
new power supply and it is running again !!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi Rene- so in the end it was a the power supply that was defective? I am having the exact same symptoms as you and the exact same LED results you had during your tests. LED 1 is on when I plug the A1225 into power. I press the power button and LED 2 lights up, LED 3 goes on for a fraction of a second, and halfway through the startup chime, the whole computer loses power and all LEDs go out. I unplug the computer and plug it back in, and LED 1 is on again. Any help would be much appreciated!
さんによる
コメントを追加
最も参考になった回答
Does the PSU look like this? If so THIS GUIDE may assist in testing the PSU voltages.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I wouldn't mind betting the voltages on the 6 pin connector are similar so you may want to measure the voltages on the 6 pin connector using the chassis of the iMac as the reference point (ground/earth) and see what you get. Also check the diagnostic LED's - remove the RAM cover to see them or you can follow THIS GUIDE for a better view. The service manual also suggests resetting the SMC, re seating the RAM. Also try booting with only 1 RAM module installed and also try each RAM module in both slots.
さんによる
OH also do you get a boot chime at all?
さんによる
コメントを追加
I Plug the iMac in, LED 1 would light up; press power button then LED 2, 3 and 4 would turn on then all LEDs turn off. I then tried unplugging the inverter (and Video cable to the LCD)... I got it to boot with external screen and will replace the power supply.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi- did you have any success finding out what the issue was? I am having the exact same symptoms as you and the exact same LED results you had during your tests. LED 1 is on when I plug the A1225 into power. I press the power button and LED 2 lights up, LED 3 goes on for a fraction of a second, and halfway through the startup chime, the whole computer loses power and all LEDs go out. I unplug the computer and plug it back in, and LED 1 is on again. Any advice would be much appreciated!
さんによる
コメントを追加
回答を追加する
Rene さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 5,336
