メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
Why aren't my ring tones working on my iPhone 4?
My ringtone and text alert tones stopped working today. The volume buttons work and when I sample the ringtone the phone plays all sounds except keyboard clips. Then, when someone calls or texts me the sound doesn't go off and it doesn't ring. Please help. I need to know when people call or text me.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 30
2 件のコメント
Thanx that's been doin my nut in for ages and I've had the white accessibility button up for other reasons for ages! Thanks a lot :-)
さんによる
Thanks a lot guys.. My phone is working again!
さんによる
コメントを追加
13件の回答
最も参考になった回答
Go to Settings>> General>>Accessibility>> Assistive touch. Then you can toggle the silent option from there. You will probably need to change the part if you want the button to work.
このアンサーは役に立ちましたか?
スコア 17
13 件のコメント:
This worked ! Perfect now I can hear my phone again :- Thanks !
さんによる
thank brother its a very helpfull for me at this time.my slider silent button is not working from last two days.so i use vibrator for for any incoming msg and call. the vibrater drain the battery of iphone very quickly and wayr i work there is no any kind charging socket for iphone
さんによる
Thank you for the solution. It worked for me. The switch stopped responding after we put it in silent, and I couldn't hear the phone ring or hear text messages come in. This was a wonderful work around for me. Thanks for explaining. Figured out the rest of the steps...
1. Turn AssistiveTouch on.
2. Tap the white button that shows up on the screen (like a new virtual home button).
3. Tap 'device'.
4. Tap Unmute. ...and Voilla, phone rings again - Yay!
5. Turn Assistive Touch off to get rid of the white button.
さんによる
Wow it actually worked like Thankyou
さんによる
woww...thankssss
さんによる
8件以上のコメントを表示
コメントを追加
My silent switch stopped working. Have tried go settings then general, then assistive touch but phone still doesn't ring. My volume up and also can play different ring tones but when someone calls my phone doesn't ring . It still vibrates .
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Thank you so much for giving me good suggestion. And now my iPhone General and silent profile working very well.
さんによる
same problem for me. Any solution for this?
さんによる
please help me with the solution cus my iPhone is not ringing when someone calls me
さんによる
コメントを追加
If you have tried all the alternatives and your phone still does not ring, your side switch may be broken-like mine was. I just discovered an app that bypasses this switch and gets your phone to work. It is called SilentAlert from app store. Its not free, but at least it solved my problem.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
THANK YOU!
SilentAlert saved me from getting the switch replaced or buying a new phone.
My switch was stuck with sound on ALL the time, a big nuisance at work.
さんによる
コメントを追加
It was a very good advice , now my phone does not vibrate and it rings .
I used Assistive touch for controlling the silent button because it dos not work any more. and then I went to the Sounds in setting and turn of the vibrate . you can check it by calling yourself with another phone :)
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for the tip
さんによる
コメントを追加
Partial answer, and a problem.
No. For me, after changing my battery, my sound slide, side volume buttons, volume icon, and default sounds all stopped working. I restored settings. Nothing. I worked to clean the charging base, and as I touched the left upper side of it inside the phone, suddenly my slide bar started to return to various applications. As I worked to gently press the charging bar, the volume slide stayed and remained stable. Partial success. When in settings, sounds, "change with buttons", as I pressed with a plastic tool on the charging bar, the volume icon (showing the bell, and the incremental volume slide), momentarily appeared (almost success, but I'm clearly on the right trail, unless this is two separate problem, i.e. buttons and sounds not functioning as they did pre battery change), and then faded out. I also tried to clean both the headphone and charging area with alcohol and compressed air. It helped a bit. I feel the charging bar may have some dirt on it, but so far no luck with the buttons or vulpine icon. I do have sound, but not default system sounds (though when pressed in settings, sound, they all function), and the mute and volume buttons, (fully functional, all, until changing the battery, all fail to function. I've taken the batter out and then replaced it (when new and wet.... with complete success. I'm SO frustrated. I've wasted hours attempting to restore these functions. The accessibility control is useful for sound, but is cumbersome and blocks one of the main controls in YouTube.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Ohh thank you guys my iphone is fix already yohoooo
さんによる
コメントを追加
I have a similar problem.
The switch itself flicks (it's not stuck) however it doesn't vibrate or make any sound. The volume buttons don't work either however I can still hear music. My sound doesn't work for things where the silent button is needed to be off (ex. Instagram videos, snapchat videos, etc.). I have tried going on to settings and turning it off silent but it still doesn't work. I've also tried turning it on and off and I haven't dropped it. Please help!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Mine just started working again as I tried using assistive touch and it now works. Bit upset that the switch itself no longer works however.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
me too about the switch itself ...
but happy that I can here my phone ring .
さんによる
コメントを追加
Plugg your phone to the computer. Open the folder "Apple Devise". (It will pop-up)
Type in the consoles "iphone(detect)/:options/:general/:sound/:volume/:call/:100;;;end;code"
That is the hard way.
Or you just go to the options and sound.
That is the easy way.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
on incoming calls, i had no ringtone or vibrate. First i changed the vibrator, but that didn't help.
So it became clear the silentswitch was gone while in silent-mode. I didn't feel like switching the audio-flex-cable, so i bought SilentAlert. Silentalert did the trick for me. At least, ringtone is back. vibrate still not working....
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
We changed the battery and it was bad , and didn't show actual charge , cause it was 65% and never moved till it was dead so I fix it send a replacement battery and all the battery issues are solved but now she has no ring tone or text tones! U can move the slide button and nothing happens???
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My iPhone 4S on iOS 9 . 1 has stopped working the silent button. Whag can I do someone places help !!!!!!!!!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
What******. Please*********
さんによる
コメントを追加
Why my mute botten is not working
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my iPhone 4s volume goes on and off. 1 minute its working the next minute its not. This cheap old phone. I should have got an iPhone up to date. But I was being stupid and cheap. Now look what I'm going through. I cant even listen to music and on top of that my mute button doesn't work. Can anything else go wrong.
Oh yeah my phone has a crack in it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Hayley さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 6
今までの合計 96,655
