メインコンテンツにスキップ
Appleによるポータブルタブレットコンピューターの全ての修理マニュアルです。修理にはヒートガンや注意深いこじ開け作業が伴います。
5719回答 すべてを表示
What is the aluminum material thickness?
I wonder about the design specs of the iPad, in regards to the material aluminum:
  • What's the thickness of the back cover of the display?
  • What's the minimum thickness, where?
  • What's the maximum thickness, where?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
Felix Klee, how about filling us in on your project??? It does start to sound interesting; first the hinges now the casing....;-)
さんによる
コメントを追加
1 件の回答
ベストアンサー
Felix - I'm sure no one here has that level of detail.
Your best bet is to talk directly with Apple after signing up as an accessory vendor. Through this special program you can get some of this info if you can explain why you need it. I should also point out you need to have a product prototype and you can't alter the iPad case (per Apples standard disclosure form).
Otherwise your next best solution is to get a junker and tear it apart to make your measurements (or replacement part).
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thanks for the suggestions! I was hoping that someone has a junker lying around and could do the measurements. Very precise information is not needed, just something to give me an idea about the limits of the material, i.e. "airplane grade" aluminum alloy.
さんによる
Apple claims it's aircraft grade. From what I can tell its pretty hard stuff, if that helps. If your questions are answered please remember to mark it accepted. - Thanks!
さんによる
コメントを追加
回答を追加する
Felix Klee さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 307
