メインコンテンツにスキップ
2008年10月15日に米国内で発売されました。
73の回答 すべて表示
I cant see my files and games insatlled in my PSP
I am having PSP 3000, I charaged it through my laptop via Data Cable. After charging There were no games and data in my memory card, it displays that there is no data in the stick.
Whereas, if i plugin my PSP into my laptop, through the data cable, i can see all games in folder, and pictures which i have captured. means the data is there in UMD card, 1.8 GB is in used outof 8 GB. Data can be seen and its opening in Laptop only, But if i open games folder in PSP, then it says, The folder is empty... Please suggest what to do... I guess software is curropted, there is some virues in it.. can anybody please tell from where to download its software for free.. and how to install it...
Please email me : ahmer.mirza766@gmail.com
Thanks..
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 16
コメント:
Hey guys! Don't know if we have the same problem. First of all, I did created the folder and named it ISO and inside it, I created another folder and named it VIDEO. I transferred the games there in ISO folder. After I transferred the games in the ISO folder, turned my psp back on, opened memory stick on games, no games appeared. Please help.
による
hey need help i haves a psp e1004 street when i put games in iso floder but it not shownging i also put update at "psp>game" but it not working
3 days ago repat the same process it work but it not show me games
による
READ MY COMMENT OK? first of all your usb cable have a problem there. try using the cable higher that your pc or use a card reader.TAKE NOTE: your psp have no problem ok ?
による
i have a problem with my psp too.I already inserted my memory stick inside my psp.It can be read but when i tried to open it says there are no games.content can be downloaded or purchased from Playstation Store.After that i check the information about the memory stick and it says Unknown.Help me how to solve this problem.
による
It's really unusual that it happened with my PSP Go on the internal storage instead of the card because i don't have a memory card. It happened in 2015, 3 years of researching and no proof. On my Linux it does show all the games, though. Glad i finally got my NES and GB games back
による
表示する 1 他のコメントを
コメントを追加
Apple Watch キット
スクリーンとバッテリー の修理が簡単にできます。
ショップを見る
Apple Watch キット
ショップを見る
10回答
最も参考になった回答
Hi, if u have a bad or corrupted memory card try coping the files to ur computer and then format the card using the psp. Then try putting the files back and check if u can access them. Write back on what u did. Good luck.
この回答は役に立ちましたか?
スコア 2
コメント:
I do it but is not instal
による
When I see in the folder ( when connected to PC) I need to know why
による
コメントを追加
i had the same problem i fixed it by pluging my psp without the memory stick and once i saw psp mode i putted back the memory stick in the psp and baam all my folders are back
hope it will works for you
この回答は役に立ちましたか?
スコア 2
コメント:
It worked for me, since my card reader was partly not usable (can't be read anymore) and I have been looking for an answer to this problem. Hope it works for others.
による
mine said "usb mode"
it didn't work on mine
による
i dont have a memory stick from the very start or probably never noticed when it was gone
による
It worked at me thanks!!
による
I bought a brand new psp 3000 after taking it to my home after connecting it to the Internet I found that it can't open many websites such as YouTube, Facebook and many more.
I inserted a memory card of 8 GB and whenever I try to download any game it says not enough memory.
When I downloaded some files to fix this I opened games section but my files were not there.
What can I do now?
による
コメントを追加
Connect your PSP to your PC and check if the PSP folder has the GAME folder in it. If it doesn't just make a GAME folder. And in that GAME folder create a new.txt notepad file and save it in there. Just put the games back in. And hopefully it will work.
It worked with mine, since there was a problem with the game Rockband Unplugged, but its fixed. Hope yours will be okay.
この回答は役に立ちましたか?
スコア 1
コメント:
I tried and i have my game folder but there is nothing. Plz help me
による
what should i put inside that notepad ? i mean, what words should i type in there ?
による
コメントを追加
what you all don't know the secert the right method is here just open cfw then press when ever you see a x button in the screen the system wiil restart now go to your memory enjoy''
この回答は役に立ちましたか?
スコア 0
コメント:
What do mean by "open cfw"? Are you saying the recovery mode?
による
コメントを追加
Try downloading a custom firmware, there you can recover the games when starting up your psp.
この回答は役に立ちましたか?
スコア 0
コメント:
Where i can find the cfw?
による
コメントを追加
I had the same problem i fixed it only watching this video
https://youtu.be/CayL-S7w2e4
この回答は役に立ちましたか?
スコア 0
コメントを追加
Hello everyone
I have a different problems for my psp
Right before i connect my psp to my laptop, i can see all the games from my psp and play it normally for hours. But when i want to copy another game from my laptop then disconnect the psp, there are no games left when i open the psp again. To be honest, the game and all the content is still there when i open it through my laptop. The only thing that i feel strange that the psp usually show me all the folders at once, now it dissapear and hiding inside 1 shortcut where when i open, it lead me to where all the folders are hiding but not losing any contents. Can anyone help me please? Thank you
この回答は役に立ちましたか?
スコア 0
コメント:
i have the same problem
による
コメントを追加
Hello everyone
I had the same problem i fixed it only watching this video ^_^
https://www.youtube.com/watch?v=OoivsH5T...
hope it will works for you ^_^
この回答は役に立ちましたか?
スコア 0
コメントを追加
Hello All,
I've not connected my PSP to any system but my games are corrupted.
Please i need assistance.
Thanks
Prince Felix.
この回答は役に立ちましたか?
スコア 0
コメントを追加
When you connect your psp to your laptop. The games auto hide .you have do these steps.
1.copy all the files in memory stick to your laptop.
2. Format the memory stick on laptop (2 times).
3. Put the memory stick in to the psp and format from the psp (2 times).
4.then connect your memory stick to your laptop via a memory stick adapter.
5. Paste games that you copy into iso file . Then you can see the games . If it doesn’t work you have to download pro update.
Thank you!
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ahmer さん、ありがとうございました!
統計データを表示:
過去 24時間: 15
過去 7 日: 85
過去 30 日: 409
今までの合計 58,898
