メインコンテンツにスキップ
Repair and disassembly guides for many types of Cisco routers.
Why isn't Cisco Aironet 1130G wireless access point configuring?
I have a Cisco Wireless access point (Cisco Aironet 1130G series) connected to a laptop via an Ethernet cord. In order to configure it, I need the IP address. The IP address was supposed to be picked up via the DHCP server, but that wasn't working so I used the advanced IP address scanner to find it using the corresponding Mac address. However, when I entered the IP address into the web browser, and nothing came up. I cleared the IP addresses prior to that. Any help is greatly appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Do you have both your PC system, Cisco device and your down stream Internet connection (Cable modem etc..) all connected to a common hub? Is the hub a fixed speed device and is all of the connected devices all running at the same speed? You may need a switch Vs a hub which has independent speed sensing ports so you can inter-connect the devices together (if they are running at different speeds).
Also check your cables are the OK are they Cat5 or Cat5e (don't waste your money on Cat6 cables)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Collin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 349
